Another guitar http://www-.luthiersforum.com/forum/viewtopic.php?f=10106&t=30797 |
Author: | Jeffkos [ Fri Jan 21, 2011 9:44 pm ] |
Post subject: | Another guitar |
Here's a look at another guitar I've been working on. These were taken before paint. I hope to have it painted in a week or two. Attachment: AW5 - (35).JPG Attachment: AW5 - Full view.JPG This one has two planks of maple in the middle, followed by a plank of walnut on each side, followed by ash. Attachment: AW5 - Front zoom.JPG Attachment: AW5 - Front side.JPG Attachment: AW5 - Back.JPG It's basically wired like a Strat, except that in the middle switch position, instead of getting the middle p-up only, you get the bridge and neck. Here's a few photos of its precursor. This one only has 2 p-ups. I've since softened up some of the curves on the un-painted one. Attachment: AW-3 - Front body.jpg Attachment: AW-3 - Players view.jpg Anyhow, there ya go. Any and all comments, critiques and questions greatly appreciated. Jeff |
Author: | npalen [ Fri Jan 21, 2011 10:23 pm ] |
Post subject: | Re: Another guitar |
Awesome work, Jeff! Do you finish the contours by hand? Nelson |
Author: | Jeffkos [ Sat Jan 22, 2011 12:14 am ] |
npalen wrote: Awesome work, Jeff! Do you finish the contours by hand? Nelson Nelson, Thanks for the comments! Regarding the finish: I need to sand them afterwards, if that's what you mean. However, the CNC gets them pretty close to where they need to be. I'm still experimenting with stepover distance; but I get pretty good results with a .05" stepover, using a .50" ball end mill. Jeff |
Author: | Sheldon Dingwall [ Sat Jan 22, 2011 8:42 pm ] |
I like this one even better. How do you fixture and reference the body to work on the back? |
Author: | Jeffkos [ Sat Jan 22, 2011 10:17 pm ] |
Sheldon Dingwall wrote: I like this one even better. How do you fixture and reference the body to work on the back? I machine "tooling holes" into the front of the guitar body, either in the bottom of the p-up pockets, on the neck, or at the bridge. I then generate some mounting blocks, and press a .25" dia dowel pin through them. I use the dowels to locate and zero, and clamp the "sandwich" together with long woodscrews. Attachment: Clamping strategy - 1.jpg Attachment: AW5 - (26).JPG Hope this helps. Jeff |
Author: | Sheldon Dingwall [ Sun Jan 23, 2011 8:52 pm ] |
Screws up from the bottom - brilliant! |
Author: | Bob Garrish [ Sun Jan 23, 2011 9:29 pm ] |
Jeffkos wrote: Nelson, Thanks for the comments! Regarding the finish: I need to sand them afterwards, if that's what you mean. However, the CNC gets them pretty close to where they need to be. I'm still experimenting with stepover distance; but I get pretty good results with a .05" stepover, using a .50" ball end mill. Jeff Unique design, and good ideas on the fixturing. If you're not in a hurry to pump them out, then love thy self and get a 3/4" ball and drop down the stepover until you can get away with just rubbing off the tooling marks, though. It might make me the laziest man alive, but if it's a personal project then I'd much rather have the Fadal run for an extra hour rather than do an extra 20 minutes of sanding ![]() |
